KrashDH
Turbo Underboost and Stiff Brake Pedal, thoughts?...SOLVED!
02 Golf, 5 sp
To start off, I've read about every thread on this. I am writing this to make sure I'm on the right track, and hopefully it can be of help to someone in the future once this is solved.
Start at the beginning. Few months ago, everything fine. I could come out after letting the car sit overnight, and I would put a foot on the brake pedal while starting the car, and it would have the "soft" feel of a normal brake pedal. Ie you could tell the system was holding vacuum.
Then, I started getting a hard pedal in the morning after letting it sit overnight. So the system had a small leak. I let it be, as soon as the car would start, vac would build, brake pedal was fine as long as the car was running.
I then did some suspension work and bled the brakes with the help of a member on here.
After this, I developed and audible "click" in the brake pedal at the end of the stroke. Easy to hear and feel, always at the same point in the pedal stroke, but did not affect braking or braking power at all, but my OCD didn't like it.
This week, was driving to work. Completely lost my brakes to a hard pedal on the freeway. Also lost boost. Threw the P1538/1556 codes. The fault to ground I tracked to some frayed wires in the plug leading to the ASV So that's taken care of.
I got to work and pulled the big vac line (rubber and plastic piece) from the pump down to the brake booster. It had cracks, and I had to get home, so I salvaged the fittings and made a home brew version out of some fairly stiff fuel line and worm gear hose clamps. I inspected the nipple on the vac pump, it's got very little wiggle in it.
This worked for about 15 minutes, everything felt good. Then, it was back to hard pedal and not boost. Here's the caveat...if I drive without using the brake pedal on the freeway for say, 2-3 minutes, I can get 2-4 good pumps out of the pedal, and the turbo comes back. After those pumps use up the vac in the system, it's back to hard pedal and no turbo until I drive some more. This process repeats
I've had a set of vac lines from IDparts waiting to be installed for a while. I installed these new lines last night. Took out the check valves and tested them with a mighty vac, even though the symptoms point to a leak before the valves (since brakes and turbo go out together).
I went for about a 30 minute drive, where everything was working better than before (with my home brew line). Even the click from before went away (meaning that may have been related to a vac leak somehow?) Then pedal went hard during the drive, and the pattern of 2-4 good pumps and a working turbo, to nothing started again. This to me indicates a CONSISTENT bleed off somewhere rather than one that is happening because of engine vibrations.
What I found odd is every time I remove my homebrew line and reinstall it, or like when I changed out all the smaller vac lines, I got 20-30 minutes of a working system, then it went back to the 2-4 good pumps on the pedal with a working pedal, to stiff pedal and no turbo after a used up vac, then that would repeat.
So I do have a pump to booster line on it's way from Cascade German, as well as a new grommet to the brake booster.
I'll put this line on and hopefully it solves my issue and the leak is coming from my line I've built.
I'm curious, is it possible that my fuel line (on my home-brew hose) is collapsing under use of the brake and then expanding enough to build vac, then collapsing again under use, and that's why I'm having that 2-4 pattern with the pedal? Can't see it while I'm driving obviously...
Also, if the new IDparts line doesn't work, I'll pull the vac pump and peen the edge over and high temp RTV it. I just replaced the internal o-ring that sandwiches the pump pieces together so I don't suspect it's that.
I also don't think it's related to the N75 valve as even if this was bleeding off, I would have a turbo issue but the brakes are using the in-line check valve so they should still theoretically work correct? When all this goes down, I lose brakes and turbo.
Just want to pick your guys' brains, appreciate it!
02 Golf, 5 sp
