Owain@malonetuning
Associate Vendor , w/Business number
I grew up with snow 4-6 months of the year,sub freezing temps for most of it, and have really beaten on winter tires. Out here in vancouver it doesn't normally snow but Mark had some new Hakkapeliitta on his mk3 @ 22 psi with a diff last winter, and I've got to say I was really impressed with their traction in 30-50F rain, way better than the continental extreme contacts by 50F (10c). Ran them into the 80s and we've beaten the snot out of them. For a performance tire in lower temp conditions they're fantastic, no problems with them getting too hot with abusive road use.
Can't see them being much if any better than xice, ipikes or goodyear nordics in heavy snow(the latter two are solid cheaper options); but for performance use in colder rain? no contest. Of course winter tires aren't designed for summer use and will wear faster, once you're past 55F or so continental/michelin make solid "all season" rain tires. I've driven on ipikes at speed in ~8" of snow both on tarmac and gravel and they worked great, especially considering price. Treadwear is a consideration, any of the all season/touring tires up in the 600s probably aren't what you're looking for, harder compounds typically don't grip as well, more around 320-440 would probably be best.
Tires are your only contact with the ground and should be #1 priority in the budget.
