Old November 12th, 2019, 22:52   #1
Withkids
TDI(s): Non yet
Default A4 b5 donor car
I have been looking for a donor car for a manual transmission swap with little luck. My search only finds cars too expensive, too far, or don't answer back. I did find a 98 Audi A4 2.8 fwd. What I could find is that the axles, shifter, trans mount brackets will work. But not sure. I don't know if the shifter linkage, clutch pedal assembly and master cylinder will work. Any knowledge would be appreciated. And I did try the search before posting.
Sent from my SM-G935P using Tapatalk
Withkids is offline   Reply With Quote
Old November 13th, 2019, 11:06   #2
imo000
imo000's Avatar
Fuel Economy: Good enough
The pedal and master/slave cylinder will work. Not sure about the shifter linkage but the shifter boot can be modified to make it fit really well. I did all this to mine.
imo000 is offline   Reply With Quote
Old November 13th, 2019, 14:43   #3
Withkids
TDI(s): Non yet
Thanks. They looked the same but was not sure. Hopefully someone else will verify the linkage, if not I can always modify it.
Old November 15th, 2019, 07:39   #4
imo000
imo000's Avatar
$hit, what do you have to loose? Just try it and if it works, post it so others in the future can learn from it.
Old November 15th, 2019, 12:58   #5
Withkids
TDI(s): Non yet
I will if the person responds back to me. Another ad that apparently the seller doesn't want to sell.
Old November 18th, 2019, 12:16   #6
imo000
imo000's Avatar
Probably sold that's why. People are too lazy to remove their ads.
B5 a4 8v pd drag car build Machineman TDI Power Enhancements 22 November 6th, 2016 01:30
Brake Upgrade <312mm , Audi A4 B5/Passat B5 Dankemp Upgrades (non TDI Engine related) 1 June 29th, 2013 09:12
Wanted: wrecked TDI car (donor car) B4 or MK3 (Western US) VW-TDI TDI Cars for Sale/Wanted 1 July 31st, 2010 01:23
Possible donor car... rgell TDI Conversions 0 August 9th, 2008 10:38
Organ Donor Needed: Got a blown A4 turbo? Betzel TDI Power Enhancements 12 September 29th, 2003 09:49
Page generated in 0.13165 seconds with 11 queries
[Output: 71.69 Kb. compressed to 62.73 Kb. by saving 8.96 Kb. (12.49%)]
