Yes, it has an intercooler. It is an air-to-water-to-air type.
The charge air cooling is done via a heat exchange in the intake manifold with coolant, then that coolant carries the heat to an additional radiator up front, where it is released into the air.
There is an additional electric coolant pump tasked with the purpose of circulating this coolant path through the intercooler and additional radiator.
