Airgreasemonkey
Hello Everyone,
New to the forum. Just picked up my 2013 TDI a month and a half ago with only. My car has 36k miles on it. I don't know if its due to the cold or just dumb luck, but after starting the engine the clutch pedal wont fully retract. I can pop it back out with my foot or pump it a few times and it will come out most of the way. After doing so the pedal is dead for the first 1/4 of the pedals travel. Eventually it will return to normal after driving it a bit. This morning on the way into work it never fully returned to normal. Thankfully the friction point is close to full travel of the pedal.
My question is, does this seem like a Clutch Master Cylinder or a Slave Cylinder Problem?
Id really like to not pull my transmission to change a slave cylinder but I do have the facilities to do so.
TIA,
Jake
TIA,
Jake
