Withkids
I have been looking for a donor car for a manual transmission swap with little luck. My search only finds cars too expensive, too far, or don't answer back. I did find a 98 Audi A4 2.8 fwd. What I could find is that the axles, shifter, trans mount brackets will work. But not sure. I don't know if the shifter linkage, clutch pedal assembly and master cylinder will work. Any knowledge would be appreciated. And I did try the search before posting.
Sent from my SM-G935P using Tapatalk
