tdi'd
Here’s the set up. This past week shifting into 3 and 4 has been difficult. So I decided I should check and change the transmission fluid. I don’t have jack stands but have two scissor jacks. Got the 17mm hex bit I need and started.
Put the car on ramps to get the panzer plate off and check that I could loosen both the drain plug and the filler plug. Did that and was able to back them out a bit. Took the car off the ramps and jacks up the front end. (My front end is lower than the rear. Measure the distance at the rear and front end. Car was level. Drained the trans. Cleaned out the plug. Put it back in. Took out the filler plug. Put two quarts of pennzoil synchromesh in. As I was putting e second quart in oil started coming out of the filler cap. I know this should happen put 2 quarts does not equal 2 liters. Less than two quarts made it into the trans. I sat around around for a bit thinking. I measured the oil that came out of the trans. It was less than 2 liters. (I poured the fluid into an empty 2 liter bottle. It was around where the sticker sits on the bottle.) Less than 2 liters came out the trans.
I’m thinking I should drain it again, keep it up on the ramps and just put 2 liters in. Maybe weight a little longer for it to drain. Or drain it off the ramps, jack it up high and fill it up with 2 liters.
This seemed pretty straight forward but I’m not trying to destroy my transmission. Another reason why I decided to change the fluid was to see if shifting continued to be difficult after wards. I don’t want to drive the car right now as I’m unsure if I have too little or two much fluid in the trans.
Any comments, questions, concerns, or criticisms are appreciated.
~ your friendly wannabe shade tree mechanic
