AC is pretty binary with only modest currnt draw changes due to temps. What changes is cycle time, so loading is still based on full draw. So, for my unit, I see about 6kW draw. Looking at the Tesla S, with an 85kWh battery, hell will freeze before a 1kW charge rate will charge it overnight. At the 1kW rate, you are looking at at least 85 hours, not accounting for losses, to replensish a flat battery. So, lets say you get from 10 PM to 6AM lower rates . . .8 hours. That requires more like a 12kW charger, which, ironically, is what you get fro a 50A outlets, which most EV makes recommend as a home charge source.
So, typically 1 AC per home, 2 to 3 cars, if we went full electric, even if all AC was off at nignt, the EV load would be at least 4x to 6x the daytime AC load . . . . and down goes the grid . . . And I think my estimate on the number of cars vs AC units is drastically low, not to mention a lot of residential AC is used more in the eveninng/night when folks are not at work. Slow charge sounds great, right until you realize that in most cases it just won't work. Again, using the S, 85kWh is 265 miles, so 8 is 26.5 . . . just not going to cut it for most folks . . .
- Tim
