Eddie_TDI
"Anyway, the leaks when switching to HPR or renewable diesel might be considered a warning that your pump seals are aged. The pump will probably eventually start leaking no matter what fuel you run."
Probably true. But your pump may last another 100k miles if you don't switch to HPR. I've got 380K miles on my TDI with no leaks fron the original pump. I don't want to switch to HPR now to see what happens.
