That's what I did. Bought the big box of Peak DEF from Walmart and one Kruse bottle of AdBlue from the VW dealer to use as the reusable filler. The top screws right off.When I took mine in for first oil change a few weeks ago at 9700 miles, DEF light hadn't come on. When I looked at what they did on service order,it says it was topped off,but no qty. or part#. When a survey was sent by email, I questioned the adblue qty. and part #. I was told they top it off using containers from other vehicles that they top off with. I don't know why VW didn't put a gauge you can pull up to let you know how much is remaining. I was thinking of just topping it off myself now -WalMart has their brand for a little over $4 a gallon.
There's no reason one can't top off the tank prior to the 10K mile mark, or, for that matter, at any time, correct ? Rather than wait for service or a warning light (I'm at 7K miles now), I'd rather know it's not going to throw a warning light or have to find the fluid while on a trip.That's what I did. Bought the big box of Peak DEF from Walmart and one Kruse bottle of AdBlue from the VW dealer to use as the reusable filler. The top screws right off.
Mine use 1.67 gallons per 10,000 miles, pretty much the same as my 2012 NMS did.
Correct, you can top it off whenever. Ironically I had it go off when I was out of town and with being in and out of the car I didn’t want the reminder every startup. Found a Pep Girls nearby and got the Peak stuff as it was all they had.There's no reason one can't top off the tank prior to the 10K mile mark, or, for that matter, at any time, correct ? Rather than wait for service or a warning light (I'm at 7K miles now), I'd rather know it's not going to throw a warning light or have to find the fluid while on a trip.
How does that work? Do they have a fitting that matches our Ad-Blue tanks?you could also stop by the big truck stops that had def pump for sale at 2.70 gallon and toss in 5 gallons when the light comes on, less mess and hassle other than many times you have to pre pay and they laugh at you when you ask for only 5 gallons.
Every 10k is a good time, but a full tank should last almost double that.AdBlue? No one at the dealer mentioned this. Is this tge DEF stuff? At what mileage interval do you add it? Yuk!
Nope the pumps handles at the stations have this long slender flexible tube attached to the nozzle, it just slips in the filler neck in the trunk, think catheter, then you just pump away. Biggest issue with this is you have no real idea how close you are to the top so thats why if you toss 4 gallons in when the light comes on you'd prob fill it to 80% or so.How does that work? Do they have a fitting that matches our Ad-Blue tanks?
Excellent. I’ve always considered it but feared the nozzle mechanism would be too big and geared only toward big rigs. I like the idea of getting fresh (and cheap) juice.Nope the pumps handles at the stations have this long slender flexible tube attached to the nozzle, it just slips in the filler neck in the trunk, think catheter, then you just pump away. Biggest issue with this is you have no real idea how close you are to the top so thats why if you toss 4 gallons in when the light comes on you'd prob fill it to 80% or so.
Also while you're there make sure you grab a hot dog at the truck stop, nothing beats truck stop hot dogs.
Preposterous that the dealership doesn't know what diesel exhaust fluid is. Maybe they don't recognize dried urea, but DEF is spilled by their OWN technicians filling the DEF tank, and those same urea crystals look the same coming from the urea injection plumbing/pump!!!Thanks. I'm seeing white spots on the motor right side firewall extending down onto the ABS unit. Some wetness, too.
Dealership is clueless as to what it is.
Just where is the AdBlue pump and line??
2750 miles on the ODO.
I just filled up at the pump a couple weeks ago, easy as can be using the pump at the truck stops. Only thing to mention is that the nozzle is stored upright so I would suggest dumping out whatever fluid is sitting in it so you dont dump it on the side of the car like I did when you go to insert it. But ya works just like a fuel pump, I didnt try to see if it shuts itself off though, instead I just listened for it to start gurgling and then took it out before it had a chance to overflow or anything.Excellent. I’ve always considered it but feared the nozzle mechanism would be too big and geared only toward big rigs. I like the idea of getting fresh (and cheap) juice.
Industry standard DEF consumption is 3% of fuel consumed. 100 gallons of fuel should be about 3 gallons of DEF.
In the 2012 - 2014 Passats with DEF, actual consumption is more like 1%, which is why they failNOx emissions tests. More about that in the emissions scandal thread.
For those of you monitoring your AdBlue consumption, please note it as % of fuel consumption so that we have a standard to use for comparison.
Could be variable. I think these cars are individually tuned because of normal variation and differences in off the shelf component parts. Kerma TDI modifies your stock tune instead of completely erasing and overlaying a new tune. I suspect it preserves individually unique look up tables and constants generated when your car is setup by VW.I'm coming up on 60k on the odometer and I still don't even know what the "low DEF" warning indicator looks like. It's never come on. I even took a 2,000 mile road trip this summer averaging around 75 mph all highway, with a fully loaded car, 3 passengers, a roof top tent mounted on the roof, and a hitch mounted carrier. If there was any increased consumption, I haven't noticed.
I'm 1,000 miles out from my second oil change since getting the fix and if there is a significant DEF consumption increase I haven't noticed. I only have my car as a reference but it doesn't sound normal to have the low DEF warning come on if you're topping off the DEF every 10k miles
