Winter tire set up
BobbyWires
Northern VT
2015 GSW manual, 1991 Syncro Vanagon, 2004 Audi A4 Avant 6man, 1990 Ford F250 351 "farm truck" 2014 Q7 TDI Sline
It's that time of the year. Will 15 inch wheels fit ok on these 2015 GSW ? Want steelies with the new Nokia Hakka 9's either 195/65R15 or or maybe the 185's
ETKA shows a 15" steel wheel for those cars, and I know the A6 cars could use a 15" steel wheel BUT I am not sure about the A7s like yours. I would think it is the same.
The A5 base model Golfs (Rabbits) used a 15" steel wheel with 195-65-15-91H tires. I think my 15" snows are Q speed though.
BobbyWires
Northern VT
Anyone know where 15 inch steelies can be bought besides dealer? Tire rack seems to only have the 16's
South of Boston
16" steel wheels are available from Tire Rack. They don't have 15s, although 15s will fit on your car. I thought about getting some Jetta S steel wheels from a wrecking yard, but I'm not sure if the offset is the same on the two cars. Bet it's not terribly different, however.
Mike in Anchorage
Anchorage, AK
2016 Touareg Lux, 2015 Golf Sportwagen SE, new 4 Sept 2017;2009 VW Jetta TDI Sportwagen (Ruby) sold to VW on 22 SEP 2017
I'm running 16" alloys with Blizzaks. Doing well so far in the snow and ice we have. I've not pid attention to the offset, but the wheels are the same I used on the '09 JSW. There have not been any rubbing or tracking issues.
740GLE
NH
plug in you're car as a 2006 "jetta s" and tire rack should show 15" steelies, this is what I had to do when i bought them for my old 2010.
20IndigoBlue02
Was North NJ, now SoCal
2002 Golf TDI-- deceased
"MK6" JSW's could use 15", if you swapped carriers and rotors to 288mm brake setup of the 2.5L. Then after winter, you would have to swap back to the 312mm carriers and rotors of the TDI
Anyway, it's easier to go through the dealership, as the wheels will bolt right up, using the stock lug bolts. Getting an aftermarket steel wheel may run the risk of needing additional hardware to install the wheelset. Though TireRack will install the tires onto the wheels for free, so you have that convenience and cost savings
740GLE
NH
But this is a MK7 folder, MK7 TDIs don't need to swap crap, 15's fit from factory.
badnews
Colorado
2015 Golf Sportwagen, FWD, Manual6
Do you want steel rims just because they're cheap? Or some other reason?
I just bought some 15" alloys from Tire Rack for my 2015 GSW and put on the studded 185/65's left over from my SAAB. Paid about $400 altogether.
Not sure if I'll go for 195/65's when those wear out, seems like the narrower tire will cut deep snow better, but the speedometer will be more accurate.
20IndigoBlue02
Steel wheels aren't exactly aesthetically pleasing. They are for the cheapness factor, so that you can spend more on tires if you want.
FOr lug/hub cover, there is 5N0071456XRW (4 pack), but if it was like last year, they may be backordered, and the best way of getting them is through the dealership where they need the VIN with the order.
tdidieselbobny
Stafford,NY (WNY)
'03 Galactic Blue Jetta TDI, '15 Silk Blue Golf Sportwagen TDI
Keep an eye out on craigslist, you can usually find a set of alloys cheap. I may buy an extra set I see if they're still available. I still have the rims from the '16 Jetta that I bought, even though they're 15". They were from early 2000's Passat I was told. Guess I need to clean them off and get them on shortly to kill the fuel mileage some more:rolleyes:...
740GLE
NH
I kept my biolines from my 2010 jetta because I knew I couldn't get crap for them on craigs list. I couldn't justify maybe letting them go for $200 to then spend $400+ on replacement rims.
BobbyWires
Northern VT
Ended up buying 15 inch steelies on Amazon 240 delivered. Used ones were out there just too far to drive. I've bent several alloys up here these dirt road beat rims and suspension parts so steel wheels make sense. Ill take some pics once they are on
740GLE
NH
If you bend a 15" rim with 195-65 tire, I want to see the video of it, a rim is probably going to be the least of your worries.
BobbyWires
Northern VT
I agree , Maybe these factory alloys are weak but I've bent a few and it's just slight so it slowly leaks. It'll be a good test on the suspension components
ssffnomad
Upstate N.Y.
2015, GSW, S, TDI, 6MT. 5/2017
Winter Wheel Tire ?
Traveling and not a lot of time to research. 2015 GSW TDI S. Could you please tell me if 16x7J ET 45 Wheels will fit ? Thank You
South of Boston
They should fit. 5x112 is the lug pattern. I forget the center hub diameter.
