arjax
Starting this swap with a 04 Passat with a blown transmission. Have the engine out and will begin the process of deleting the balance shaft.
Some quick questions that need a little help with:
1) Motor mounts - I am buying new mounts as my allroad currently has Sterns and I don't want to use them. Which seems better going with allroad specific mounts or picking up ones from a Passat?
2) Looking at the DMFW from Luk - I read that an EU starter and 5.5mm space must be used. Is the part numbers for the starter 068911024H? Is the part number for the spacer 01e103551B?
