Making a stock AHU survive 30-35psi
This might be a bit premature seeing as how I'm probably a good 2-3 months from this being a reality, but hey I like to plan.
I have a stock AHU block with 300k km on it that I'm using in a swap. I also have a vnt-15 and a td04-13 that I'll be throwing on in compound. VNT-15 will be going on as a single first just to get the swap moving and work out the bugs then the td04 will go on. I know they're not perfectly matched but I should be able to run 20-25lbs@ 3k rpm with both turbos in their peak efficiency so it'll make a good towing setup for the truck. The td04 should be able to flow something around 25lbs of air. I've been playing around with the not2fast turbo calc and based on what I've got from there I'm hoping to run 20psi at 2krpm if I can get it and ramp it up to 35lbs at 4750 where the LP should just start to choke.
Whitbread had suggested that I use a k03 instead of the vnt to simplify tuning so I'll be slightly heeding his advice in that I'll be running an external waste gate with the vnt-15 with the vanes in a tbd fixed position. Might run a pushpull cable on the vanes just because I like to tinker. Boost will be solely controlled by the waste gate.
Thats just a bit of back ground. The real question is how do I make the stock block survive?
My plan is:
-head studs/12.9 Cap screws
-Minimal timing on the low end.
-Maybe reduce cr? (Remove the bowl lip)
-Rod/main bearings?
-Larger than needed nozzles to keep the injection even short -> less timing needed.
Head studs or 12.9 cap screws will be in order for sure as well as being careful with the timing. I have the ability to remove the lip on the piston bowl so I'm really not opposed to doing that if its needed to keep the engine alive. I'm contemplating dong the rod bearings while the engines out but don't really want to. Upgraded rods are out of the question for a year or two. I just cant afford them.
Any thoughts/opinions? Am I missing something important or am I just nuts?
I know its a high mileage engine so I'm not expecting too much out of it and I fully expect to grenade it at some point but I'd like to make it last as long as possible within reason.
My plan is:
-Rod/main bearings?
