HI,+1 for DBW. I got my DLC 1019's from him and I haven't had a single issue. Make sure to get them adjusted to stage 3 or higher. (Think of it as a limiter, it won't hurt the injectors)
It increases the maximum flow on a percentage per stage. Stage 1 is 5%, 2 is 10%, etc. It's a physical modification done by DBW. You can send them in anytime to change it as well.HI,
I'm looking at getting 1019's but what exactly is a stage 3 adjustment?...A Tune?
Andrew
Stage 1 is the default OEM/Bosch factory settings.HI,
Andrew
Correct, We can increase or decrease at any time, we generally do a full clean and adjust when these changes are made returning the injectors back to their original overhauled condition.It increases the maximum flow on a percentage per stage. Stage 1 is 5%, 2 is 10%, etc. It's a physical modification done by DBW. You can send them in anytime to change it as well.
Sorry about the misinformation! I was only repeating what I was told when I was going to purchase mine.Correct, We can increase or decrease at any time, we generally do a full clean and adjust when these changes are made returning the injectors back to their original overhauled condition.
http://www.dbwllc.net/product/nozzle-clean-and-check-returning-customers-only/
