I'm now reaping the benefits of an additional air-liquid intercooler without spending hundreds of dollars and adding all that complexity.
A windshield washer reservior from a Mitsubishi Cordia is mounted next to the intercooler tubes of my 98 Jetta. For now, water gets siphoned to a washer nozzle mounted in the bottom of the intake box below the air filter.
The final plan is to utilize boost pressure to force water out of the reservior and through a tiny jet mounted on the existing vacuum fitting above the turbo. That vacuum fitting is higher than the reservior, which will prevent water from being siphoned out while the car is parked.
This initial setup might be crude, but gosh it works. Turbo lag is gone, and the engine revs right up to 4000rpm. Its worth a dyno test.
Skypup should have done this, instead of routing the A/C air to the intercooler.
Be very careful, too much water in the engine will kill it dead. This is a perfect way to steam clean all that PCV oil from the intake tract.
Keith.
Keith.
