J.P.
- Joined
- Aug 14, 2007
- Location
- Northern MI
- TDI
- Black 05 b5.5V/6spd w/274k miles (daily). Silver 02 Golf/5spd w/240k miles (fun 1). Mint Tornado Red 01 Golf/5spd w/440k (ALH still perfect!!!).
I've got a OE spec VW 80AH battery in my 02 Golf. It replaced the original battery in December of 09 (original went 6.5 yrs). Hygrometer indicates it has one bad cell. I discovered it because it would not start when I returned to the airport after 8 days (temps were in the 20s, but had not been that cold for the duration).
I would expect better than 3 years for the OE battery, but I wonder if I have some responsibility. Could what I put it through in May, or lack of attention to electrolyte this year have toasted it?
Is there a chance of a desulfating battery tender bringing the battery back?
Background:
In May I had a 2 week trip and left the lights on at the airport (drivers door interlock is out) resulting in a very dead battery. Dead enough that after driving for 40 minutes after the jump, it still wouldn't re-start and had to be jumped again to get home. Battery got charged with my "automatic" (no choices in charge rate, but has charge and maint modes) battery charger, but I did not check electrolyte levels. I also did not check electrolyte levels for the first 2 years of the battery.
After the most recent no-start I checked things out. Electrolyte was low in all cells (last checked and topped last Dec '11) Maybe 1/2 cup total to fill all 6. One cell has very low specific gravity, the other 5 are good. Charging system voltage is a steady 14.3 volts when the engine is running.
Right now, if I'm driving the car regularly it is starting w/o a problem, but if it sits for a bit it barely turns over after the glow plug light turns off.
Background:
