bigwoode
*****UPDATE POST #78!!
More and more people are probably starting to recognize me based on my threads over the past 11-12 months. Please be patient with me, I will organize this as best as I can. Thank you in advance to anyone who might be able to help shed some light on this situation: (GURUS whom might be interested in helping, see statement at the bottom)
CAR BACKGROUND:
2001 ALH Jetta
275,000+ Kilometers
Runs on Biodiesel Blend with D2 (variant on temperature) (235,000km on D2, 40,000km on Bio)
NEVER RUN ON WVO!
1st PROBLEM:
-Air is being sucked from the fuel filter (via clear line) into the engine. This is causing low power, jumps in power, long stressful starts (warm and cold), and sometimes full engine stall.
-There used to be a certain level in the tank; when reached, air would begin to slowly appear in the lines. As long as I kept the tank full, and didn't let it linger too far past 1/2 tank, the car wouldn't stall on me.
-When under heavy acceleration/WOT, the problem is much more apparent (obviously, of course).
TECHNICAL QUESTIONS:
1) If there was a problem with the injectors/lines between injectors, COULD AIR BE RETURNED TO THE FUEL FILTER VIA THERMOSTATIC TEE?
2) Do the connections between fuel fittings (send/return blue/black lines) have the potential to leak? I have not seen anything visibly as far as leaks are concerned, but could these fittings suck in air?
WHAT I HAVE DONE/REPLACED:
-Fuel Injection Pump Resealed x2
-Current temporary swap does not leak.
-Fuel Filter 3-5 times
-Thermostatic T (03/09)
-Viton O-Rings (03/09)
-Fuel Sending Unit x 2 (most recent was 09/09)
-Fuel Sending Unit O-Ring (10/09)
-Fuel Line (sending unit ---> under car ---> up into engine bay blue/black) (06/09)
NONE OF THESE COMPLETELY FIXED THE PROBLEM.
2nd PROBLEM: I have a CEL for glow plug circuit (harness, I assume), have changed out 3 of the 4 plugs (the 4th is under the injector line). Also have ABS Sensor on... (skip to WHAT I AM WILLING TO DO)
OTHER VARIOUS PROBLEMS:
-Trunk latch broken, will not lock closed, but will not fly open.
-Small amount of oil consumption every 2,000-3,000 miles --- usually 1/2-1 quart.
WHAT I AM WILLING TO DO: I am somewhat mechanically inclined, but being a 21 year old college student with 2 jobs has occupied enough of my time to where I cannot spend day and night diagnosing these issues.
-I am willing to drive to ANY TDI guru in the Northeast (or within 10 hours of Buffalo, NY) who feels they can help diagnose my problem.
-I am willing to purchase any parts to end this misery.
Thank you to everyone if you made it to this point and have listened to my story. Thanks in advance for any advice. If there is additional information you would like to know, please alert me and I will answer any questions.
CAR BACKGROUND:
2001 ALH Jetta
275,000+ Kilometers
NEVER RUN ON WVO!
1st PROBLEM:
