BSpray29
I had the LCD display go bad on the stereo in my 06 Jetta TDI. I could only see about 10% of the display. Maybe it was from the heat here in Georgia, I dont know, but I was able to fix it and wanted to share this with everyone in case you have the same problem. I went on Ebay and found a factory stereo for just $30 including shipping. You can get them dirt cheap on Ebay because 90% of the ones for sale on there do not come with a security code. When I received the donor, I removed the entire front panel and then removed my old radio in the car, but did not disconnect it, and replaced the old front with the one from the donor stereo. I reinstalled my old stereo with the new front panel and it works perfect! Since I did not disconnect my old stereo, I did not have to worry about having a security code to get it to work again. The front panel of these stereos just pry off from the bottom and are attached to the "guts" of the unit by 2 ribbon cables. All you have to do is plug them in. Hope this helps someone!
