6DOF
- Joined
- Sep 16, 2006
- Location
- Senatobia, MS
- TDI
- 2011 TDI Jetta 6MT Premium, 2012 TDI Jetta DSG Premium
So we had our 2012 Jetta in the shop already this year for a cracked DPF and bad temp sensor. It was covered under the emissions warranty and not a big deal. Now my daily drive, the 2011 Jetta is throwing the same code that the 2012 was. My 2011 has 90K miles so its' emissions warranty is expired.
It seems to me that it is only a matter of time until this system fails. It cost $1,954.61 to fix the cracked DPF and temp sensor which I am thankful that the emissions warranty covered.
You can clearly hear an exhaust leak from under the car where the DPF is leaking. The 2012 had the same exhaust leak sound.
Before I shell out 2K from my pocket to have this replaced I had a question for all of you knowledgeable TDI club viewers:
Will the upcoming dieselgate fix from VW take care of the emissions failures?
1 Fault Found:
001025 - EGR System
P0401 - 001 - Insufficient Flow - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 143093 km
Time Indication: 0
Date: 2015.11.04
Time: 08:18:44
Freeze Frame:
RPM: 2415 /min
Speed: 142.0 km/h
Voltage: 14.14 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 645.0 mg/str
If I have to shell out $2K to fix it then why not pay $2500 and have it deleted and tuned? That way I never have to worry about it again?
1 Fault Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 143093 km
Time Indication: 0
Date: 2015.11.04
Time: 08:18:44
Freeze Frame:
RPM: 2415 /min
Speed: 142.0 km/h
Voltage: 14.14 V
Load: 100.0 %
Load: 100.0 %
