TurboDieselPoint
It seems cracked DPFs are a growing issue with the CBEA and CJAA. The conclusion most people jump to is that they are cracking due thermal stresses from hot shutdowns or are failing due to manufacturing defects, but I thought of another cause that might be the source of trouble for those with cracked DPFs.
Could these drivers be cracking their DPFs when they run over potholes or other imperfections in the road's surface that would cause a shocking jolt to the rest of the vehicle? I'm not suggesting the DPF is hitting anything, but rather the bone-jarring shock from a high-speed encounter with a pothole would simply fracture the ceramic "honeycomb" inside the DPF.
Discuss.
Discuss.
