Old November 29th, 2014, 12:25   #76
JLMurphy
Great DIY, many thanks. I'm working through my first timing belt on my '10 Golf and I think I've got everything lined up and good to go. The only thing is that in my case the cam and HPFP gears aren't quite centered, both are a bit clockwise. The timing lines up perfect between cam and crank and the HPFP is very close but I'm wondering if I need to worry about the cam and pump gears being rotated in their slots a bit. I think both gears are 1 tooth off of the centerof the slots, and I'm not looking forward to taking it apart again to fiddle with them.
Here's the cam:
And the crank:
Finally the tensioner, hard to tell from the angle, but the pointer is at the far right edge of the slot.
As you can in the pics, the bolts are toward the rear of the slots. Is there any risk here? As long as the timing is spot on I think I should be ok, right?
Oh, and with the water pump I set the pump in the block, started all of the bolts by hand and then tightened each a couple of turns at a time. Seems to be seated perfectly.
Thanks again for the DIY, it's a big help. Overall this was way easier than my ALH, and about the same as my PD. The HPFP isn't too terrible, but the belt was pretty stiff in the cold and was a bit of a pain to wind around all of the idlers and gears. Took a couple of tries and a helping hand from my lovely wife, but we got it on.
Jim
JLMurphy is offline   Reply With Quote
Old November 29th, 2014, 13:22   #77
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Hi Jim. Nice work! I would take the time to move the sprockets so the bolts are centered. The risk is that the bolt is at the end of the slot and is preventing the belt from being tensioned properly. If that isn't the case and the bolts are NOT contacting the edge of the slots then yes you can continue forward with the change out...but I really would center them.
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old November 29th, 2014, 14:39   #78
JLMurphy
Thanks for the feedback, I was concerned about bottoming out in the slots so I checked the clearance when I changed out the bolts for new ones and there was ~1/2 bolt diameter clearance on both the cam and HPFP gear slots, basically to the edge of the washers, so I have to say, I left it alone. The prospect of pulling the belt again did not excite me.
One thing I noticed is that when I put the belt on with the gears fully clockwise they didn't move much when I put some tension on the belt. That's why they ended up a bit off center, they just didn't move much when I tensioned the belt.
In any event, it fired right up when I got it back together. I think I ran the fuel pump test about 5 times to make sure it was fully primed.
Thanks again for the awesome DIY, it made the job very straightforward.
Old February 8th, 2019, 20:52   #79
Brent4
I realize this is an old thread, but I have a question for the pros. Pardon my stupidity but what is the reason for the long procedure? Why can't you just hold the sprockets from turning and release the tension and slide the old belt off and the new one on? I'm sure there's a reason but I'm just not seeing it. I read the instructions by greengeeker, very detailed and excellent. If someone could just explain the reason for the procedure....
Brent4 is offline   Reply With Quote
Old February 8th, 2019, 21:13   #80
oldpoopie
oldpoopie's Avatar
Interference motor.... get it wrong.... well..... why dont you try it and let us know.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old February 9th, 2019, 06:25   #81
Brent4
But what could you get wrong if the cog count is the same between the sprockets on the new one as on the old one? I don't want to just try it and blow it to pieces. The hardest thing for me to understand is why you'd have to loosen the bolts on the cam and HPFP sprockets.
Old February 9th, 2019, 07:12   #82
oldpoopie
oldpoopie's Avatar
If you don’t loosen the bolts when you tension the belt the tension only travels between the two pullys on either side of the tensioner and not the entire belt
Old February 9th, 2019, 09:23   #83
Brent4
Of course. Never thought of that, I'm so dense. Thanks for explaining
Old May 17th, 2020, 08:56   #84
bulldogger1
Fuel Economy: 40/city 55/hwy
Just finished TB job on the CJAA.
Whatís the trick to tightening the harmonic balancer bolts to 10nm + 90 degrees?
My car is a DSG and the crank keeps spinning. I canít get enough torque on them.
PS. My DieselGeek kit did not come with replacement bolts for the balancer. Hope thatís not a problem.
Any advice is greatly appreciated.
Faith? You have to believe it to see it.
bulldogger1 is offline   Reply With Quote
Old May 20th, 2020, 21:30   #85
greengeeker
I've been torquing them to a straight 18 ftlbs without issue.
- Nick -
Old May 20th, 2020, 21:43   #86
oldpoopie
oldpoopie's Avatar
Me too
Expected Life of V6 TDI Common Rail Pump Belt?? hedditch VW Touareg TDIs 9 April 20th, 2011 08:25
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 20:33
Timing belt procedure Metro VW MKIV-A4 TDIs (VE and PD) 15 July 21st, 2001 00:39
Timing Belt Procedure bighands VW MKIV-A4 TDIs (VE and PD) 20 March 21st, 2000 21:01
© 1996 - 2020, All Rights Reserved
Page generated in 0.17215 seconds with 11 queries
[Output: 108.78 Kb. compressed to 92.95 Kb. by saving 15.83 Kb. (14.55%)]
