Old January 25th, 2012, 21:55   #1
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Default How To: Common Rail Timing Belt Procedure
All in all, not a bad job. Very similar to a BRM job mixed in with some ALH bits. Special care needs to be taken since you crack the fuel system and need to completely bleed all the air out. Because of this I wrote a supplemental how-to at the end on how to run the output test as well as the basic settings test (is there already be one of these?).
I've also thrown in a little more information explaining the proper use of the BEW/BHW/BRM/CBEA/CJAA timing belt tensioner during the R&R of the belt. We took some video during the job and I'm working on getting those posted to youtube.
Please let me know if you find any errors or have any corrections.
Thanks to DanG144, Kriesel, Coalminer16 for the advice, help with pictures and just overall moral support.
To supplement the timing belt procedure I created a video showing the tensioner procedure (video is of a PD timing belt but the tensioners use the same pin feature): http://youtu.be/lM13IXokpuI
Discussion in the How-To: PD Timing belt video thread
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old January 26th, 2012, 04:52   #2
DZL_Damon
DZL_Damon's Avatar
Fuel Economy: 46mpg
Glanced it over and it looks very well documented. I probably will not be able to check the small details until I do the job in another 50k miles, but thank you very much!
-09 VW TDI Loyalty Edition, DSG, FrostHeater, Black, lightened exhaust,snappier than stock, only air goes in, all exhaust goes out. 77k miles, build date 06/08
-Bunch of Cummins and various other diesel creatures lurking about the dooryard.
DZL_Damon is offline   Reply With Quote
Old January 26th, 2012, 05:00   #3
Growler
Got Soot Vendor
Growler's Avatar
looks good, gonna be fun figuring all of this out the first time.
one minor thing, all of the torx bits holding the belly pan on and side skirts on are T20 torx, not T15.
Thank for the PDF, its very well done.
one question though, do you really need to raise & lower the engine so much to get at the 3 mount bolts? or can you get at them and get them disconnected from the block and have them come out with the bracket once you loosen the final bolt? also, is this set up like a BRM where the bolts are all outside the belt path? or is it like an ALH/BEW where one of the bolts is in the middle of the path? I am hoping its like a BRM.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old January 26th, 2012, 07:49   #4
greengeeker
Thanks for the correction Aaron...I couldn't remember.
It's like the BRM. I put that order together because all three of the bolts are basically pointing straight at the frame rail. You need to raise it to even get a socket on the front one and in this position the rear one is very close to its hole through the fender. The bottom one is probably accessible but I prefer to bring the engine down to make access easier.
Of course if you are using a Herm-o-hanger raising and lowering the motor isn't as easy as if you were using a jack so you can improvise where necessary.
I'll also clean up the torque chart at the end. Defer to the ones in the text.
- Nick -
Old January 26th, 2012, 09:32   #5
740GLE
Is there any better way to drain coolant from the block instead of pulling the water pump out and opening up a waterfall?
I'm sure the coolant won't hurt anything, just looks like a mess that should be able to be done without the mess.
70,000 miles till mine!
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old January 26th, 2012, 10:15   #6
greengeeker
You can pull the lower hose on the oil cooler but you still end up with coolant coming out when you pull the water pump. Plus that hose is a PITA to get to.
- Nick -
Old January 26th, 2012, 19:23   #7
greengeeker
Looks like they are actually T25 and there are 9 of them.
- Nick -
Old January 26th, 2012, 20:25   #8
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Couple points to add. Thank you greengeeker for the nice job you did to my fathers car. Another point is the belly pan takes two sizes of torx bolts but if you are doing the timing belt I am REALLY hoping this isn't your first time taking the belly pan off. Also MAKE SURE THE TIMING BELT KIT HAS ALL BOLTS. Seems some things have changed very recently on a few of the bolt sets on the job with Bentley.
VERY VERY nice write-up.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old January 26th, 2012, 20:28   #9
greengeeker
Thanks for the help Travis.
- Nick -
Old January 26th, 2012, 21:17   #10
greengeeker
Updated to Rev 2. Can't seem to figure out why my pictures will randomly black out?
- Nick -
Old January 27th, 2012, 08:36   #11
Kriesel
Kriesel's Avatar
x2, check your bolts when they arrive in the mail, not when you have your car half tore apart...
My Garage
My Duramax Suburban
Kriesel is offline   Reply With Quote
Old January 27th, 2012, 14:11   #12
dogdots
dogdots's Avatar
TDI(s): None
Nice write up. I do not remove the engine mount on the CBEA or the BRM, I use a set of thin double nuts tightened to each other and remove the stud with the tensioner. Saves lots of time and a few bolts that don't need replacing.
Non VW: 2019 F150 4x4, 2019 Hemi Trailhawk, 2011 BMW 335D, 1977 MB 280SL
www.kansascitytdi.com
dogdots is online now   Reply With Quote
Old January 27th, 2012, 22:10   #13
JSWTDI09
JSWTDI09's Avatar
Did you update it and not change the file name? It still says rev1 so I'm not sure if I should save it (again) or not. Thanks.
Have Fun!
Don
1966 MGB Roadster (just for fun)
JSWTDI09 is online now   Reply With Quote
Old January 28th, 2012, 07:49   #14
coalminer16
TDI(s): Golf 2004
I also vote for a sticky.
Old January 28th, 2012, 16:15   #15
Plano Diesel
Great write-up and pictures. Thanks greengeeker.
I have 63k and change on my 2009 TDI. What mileage should I be looking to change out the belt? 80k? 100k?
______________________________________________
His: 2009 Jetta TDI Candy White, anthracite, manual
Hers: 2009 Jetta TDI Salsa Red, anthracite, DSG, Sunroof
Plano Diesel is offline   Reply With Quote
Expected Life of V6 TDI Common Rail Pump Belt?? hedditch VW Touareg TDIs 9 April 20th, 2011 08:25
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 20:33
Timing belt procedure Metro VW MKIV-A4 TDIs (VE and PD) 15 July 21st, 2001 00:39
Timing Belt Procedure bighands VW MKIV-A4 TDIs (VE and PD) 20 March 21st, 2000 21:01
Page generated in 0.16451 seconds with 11 queries
[Output: 140.54 Kb. compressed to 117.96 Kb. by saving 22.58 Kb. (16.07%)]
