wai-ho.lo
Hi guys,
How's everyone doing in this cold? Here's another cold start issue for you to crack. The car is an 2003 Jetta TDI, five speed, 343,XXX kms, 214,XXX miles.
Symptoms:
Numb fingers, face... Below -20 degC, -4 degF, clutch pedal returns to position slower than normal.
The OEM battery (80 Ah, the top prints 380 A DIN, 640 A EN/SAE) was tested good (less than a year old, 627 CCA), I even have a second battery (Energizer Max PG-700N, 95 Ah, 830 CA, 700 CCA) from the junkyard that was apparently load tested before I bought it. I have them hooked up as if I am receiving a jump.
When I try to crank it, the engine turns over by a fraction of a second, not even one revolution, then the dash went out, door unlocks.
When I hooked up the voltmeter it shows 12.43 V for the warm backup battery, 11.79 V for the cold original battery. When glowing, it drops to about 10.5X V, when cranking, it drops below 7.5X V.
No start with two load tested batteries! I am wondering:
1. Is the OEM battery (80 Ah, the top prints 380 A DIN, 640 A EN/SAE) the right one? I am hoping the dealer didn't give me a gas model's battery.
2. The clutch returned a bit slower to the starting position than normal, I know I have the car in neutral, probably won't affect starting that much. But would the clutch stick? I am currently using some 18-month-old ATE Super Blue Racing Fluid which advertises its 3-year changing interval. I don't race it much anymore, would it have absorbed too much water and froze?
3. Does it seem like the starter was drawing too much power and the voltage dropped too far? Perhaps the starter is shorting out? It doesn't happen when it is warmer. Maybe it turns over slower when it is cold and gives the starter a chance to short out?
I am currently warming my OEM battery and charging it inside. Let's see if it will start with both batteries warm.
Could you guys give me some inputs please? Anything would be appreciated.
Cheers,
Jason
Symptoms:
Cheers,
Jason
