Moto920
My 2009 jetta tdi has 12,000 miles. Went to start it and it would turn over extremely slowly. Almost like the battery was dead. An engine fault code came up. Not sure exactly what it was. Got frustated gave it a slight amount of thottle and it turned over. Engine then turned over at normal speed but still would not start. Then low oil pressure fault. This happened about 6 times. Vehical was towed to dealer. Dealer said it started perfectly for them and no fault codes. Dealer suggested may be bad fuel. Dealer stated, if this happens. Put thottle all the way to the floor to flush out bad fuel. I have not had any problems since. Havnt' been able to test the thottle theory.
