silvrmax04
Took the car to the dealer for its 10k service. They did everything well and even washed it. I asked ahead of time to make sure and to remind them to put in the correct oil. I told them I read the VW forums frequently and knew this was a problem. They said they have ASE certified mechanics perform this work. Two days later my wife notices this white stuff in the trunk. They spilled the ad blu all over the plastic in and around the filler neck as well as on the carpet. I called and talked with service manager about how displeased I was with an ASE certified mechanic not knowing how to use a funnel. I wasn't too rude because I knew I was gong to allow them to apologize and make it right. Well my wife took it there a few days later and they cleaned it all up, washed it and topped off the fuel. I get home and look in the trunk and the white crystals have come back on the carpet and is still in the corners. I lift the carpet and find that it was all puddled under the spare tire. The spilled ALOT. Now it is all crystalized and hardened. Is there any way for me to clean this up so it doesn't return? Also, will it ever be the same or did it eat through the paint. What to do?
