Old April 11th, 2012, 11:03   #31
paramedick
paramedick's Avatar
Watching with interest. John, please let us know how the installation went and impressions.
Old April 11th, 2012, 12:00   #32
PhunkFX
PhunkFX's Avatar
Fuel Economy: 44-46 MPG
I think that I am going to get one of these sooner than later. How long does it take to reach New York and what forms of payment are accepted?
-Ricky
2005.5 VW Jetta TDI 6MT | 185K Miles |
PhunkFX is offline   Reply With Quote
Old April 11th, 2012, 23:10   #33
john.jackson9213
TDI(s): 1996 B4V
Will do!
Just had some surgery and lifting any weight is out of bounds for about a month. So I may not get this done as fast as I would like.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old April 12th, 2012, 16:13   #34
silverbox
silverbox's Avatar
Fuel Economy: 55mpg highway@100kph
Radim,
I sent you a PM a few days ago. When will you be accepting MC payments?
KERMA tune, PDliftpump,11mmIP Race 520's. PD150 Intake manifold&TIP, 1722 turbo, Upgraded IC pipes and Eurojet SMIC.Stealth racepipe. 2.5DP+catback areoturbo2525 muffler. Peloquin LSD.
Koni FSD's +VR6 springs, 23mmRSB, 16x7w/Conti DWS. GLI Recaros, Wingnut short shifter, Ecodes w/relays+60/100h4's.
Cat2 Fuel filter DG/Amsoil Bypass filter
silverbox is offline   Reply With Quote
Old April 13th, 2012, 09:43   #35
MikeMars
This kit is interesting. I've talked to an experienced workshop about it, but they dont think it is possible to do the conversion without removing the gearbox from the car, given that the internal fork (AKA gear shift rail) needs to be changed. Are there a description around anywhere of how to perform this particular step without disassembling the gearbox?
Audi A2 TDi 1.4*, 6M/0.588, mild aero mods, 103hp remap (* 3 pot version of 1.9PD)
Y2000 Passat TDi 115 PD RETIRED, M5, Best 75MPGuk, usually 60-70. 900m clubx7. 1000 mile clubx3.
VW Fuel saving tips
MikeMars is offline   Reply With Quote
Old April 13th, 2012, 13:43   #36
john.jackson9213
TDI(s): 1996 B4V
See post 25 & 26 in this thread.
JJ
Old April 13th, 2012, 15:08   #37
EuroTuning
TDI(s): 2,0TDI
Originally Posted by silverbox View Post
Radim,
I am really sorry for the delay of response. We do not accept MC as of yet, we opened bank account at Citfin, which uses ING Bank and so the paying should be easier.
http://www.citfin.cz/en/the-citfin-c...ut-us/ssi.html
EuroTuning is offline   Reply With Quote
Old April 13th, 2012, 16:19   #38
MikeMars
Yeah I read that, but I can't tell them 'you do it through a hole', I would need to give clearer instructions than that! :-)
Now these guys have a great deal of experience with VAG gearboxes (and 6th gear conversion kits), but I have absolutely none, which means that for me it's not easy to explain to them without help. Hence why I was asking about instructions :-)
Placed my order for the kit this morning.
A .59 6th gear will be a bit longer than the .622 5th I am running now. should be nice with the stock .756 ratio for 5th gear. Fills in that hole I have now from 4th to 5th (.622).
Will post more as this progresses.
This sounds like a really good idea ... since I'd like a 6th gear which is as long as possible, the 0.59 ratio would work as a perfect 'overdrive' for motorway cruising. There would be quite a big gap between my 5th (the standard 0.75) and 6th, but that's OK.
Originally Posted by EuroTuning View Post
Diagram of John's gearbox:
My 1st to 5th gear ratios are as above, but since my wheels etc are different diameter, these result in different speeds. So 60mph = 2205rpm for me currently in 5th. A 0.59 6th would be around 1734 at 60mph, or 2600 at 90mph.
VW Fuel saving tips
Old April 14th, 2012, 13:12   #39
EuroTuning
TDI(s): 2,0TDI
Your gearbox could be modified as shown in the diagram.
Old April 14th, 2012, 13:42   #40
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Just for reference, a tire with a circumference of about 185cm is what the Mk3 and B4 cars run stock. The Mk4s are about 199cm.
The CTN code transmission is used on the Mk3 and B4s, it has a taller final drive ratio that effectively makes up for the tire size difference between the generations of cars.
So the numbers for the CTN code (engine RPM vs. vehicle speed) transmission are correct on your graphs. The later cars with the shorter 3.39 final drive have larger tires--~199cm circumference. Those graphs could use a change
Is there a plan to offer a .622 6th gear? I think with the stock 5th at ~.75 that would be about perfect.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old April 15th, 2012, 14:54   #41
EuroTuning
TDI(s): 2,0TDI
Yes, we know that even bigger tires exist, but the diagram is for displaying recommended changes of ratios. If we were using different circumferences, the diagrams wouldn't be comparable to each other.
We don't offer .622 ratio, we make only those ratios, that can be used in the most of 5-gear gearboxes. The most popular 6th gear for TDI engines was .65, which continues on .75; VW makes 5-gear gearboxes with longer 5th gear now, so we had to add .59 ratio to our special 6th gears. It continues on 5th gear .71. We are preparing 6th gear .52 for new generation of VW T5 with 5th gear .66 gearboxes. 6th gear .74 is the most used in gasoline engines.
We believe, that it is possible to build optimal solution for every gearbox 02A, 02J, 02B, 02R.
Old April 16th, 2012, 08:12   #42
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
So the question for me is what would most shops charge to install this kit along with a clutch (just labor).
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old April 16th, 2012, 22:04   #43
john.jackson9213
TDI(s): 1996 B4V
Depends on their labor rate, doesn't it? What do typical shops in your area charge for labor and how many hours do they charge for a clutch job? Guess you might want to ad 1 to 3 hours to do the kit.
JJ
Old April 17th, 2012, 00:21   #44
MikeMars
It would also depend on whether they manage to figure out how to modify the gearbox while still on the car, or if it is a gearbox removal & disassembly job.
Audi main dealerships here in the UK charge $170 - $300 per hour (at current rate $1.58=1), but they wouldn't touch anything non-standard in any case. I think the tuning shop I normally go to for everything is about $120/hour. I suspect it will be cheaper on your side of the pond :-)
VW Fuel saving tips
Old April 27th, 2012, 22:53   #45
john.jackson9213
TDI(s): 1996 B4V
Just noticed Eurotuning has edited the first post to include instructions on how to do the install without pulling the transmission from the car.
JJ
FS- 02J 5 speed Manual Tranny conversion kit w/ LSD & 3.16 R&P for Modded car tothemax Private TDI Items for Sale/Wanted 15 January 31st, 2011 16:56
WTB: 6-speed conversion kit 02M X@V Private TDI Items for Sale/Wanted 0 January 20th, 2010 10:00
01m to 5 speed conversion kit bryanbryan89x Private TDI Items for Sale/Wanted 2 August 7th, 2009 16:33
Looking for 5 speed swap kit, Shock/struts and TB kit GTA or Canada barriesr/t Private TDI Items for Sale/Wanted 0 January 1st, 2009 07:07
greasecar conversion kit mrup TDI Conversions 1 October 31st, 2006 22:32
Page generated in 0.18647 seconds with 13 queries
[Output: 141.49 Kb. compressed to 119.29 Kb. by saving 22.20 Kb. (15.69%)]
