Good evening,
I planed to fit BHW pistons in a 1.4 TDI. However, I totally forgot the bore of the headgasket. (which is max 80,7mm)
It seems like it isn't possbile to use the 2.0 TDI head gasket as there would be a problem with the oil supply. (thanks to Rub87!)
Does anybody know if there is an easy way to cut the holes on the stock headgasket, so one could fit BHW pistons?
Thanks in advance
David
Thanks in advance
David
