I just wanted to check if anyone had any experience with biodiesel in a 2006 PD BRM.
I've been thinking about running BioDiesel for a while now to help keep by TDI around for a long,long time. (and be a little more environmentally friendly, etc,etc)
I'm at 91k miles, just changed my timing belt.
* I run the proper VW spec oil and change it religiously.
* I run straight Diesel Purge once and a while.
* I also have a new fuel filter in the mail (it's time for a change)
As I need to change my fuel filter anyway I thought it would be good time to make the switch to biodiesel prior to changing the filter out.
Thoughts? Car warranty expired long ago.
I know VW supports B5, but the only pumps in Houston carry B100... so the amount will be a little hit or miss as I mix with the diesel in my tank.
Thanks!
Thanks!
