DieselRacer
banned
My stage 2 to stage 3 got me .3 seconds of my quarter mile time...
I also was going to stay with Stage II. I was content but looking for a bolt on turbo like this. My days of being a pioneer with R&D and spending cash & not having a reliable vehicle are over. This set-up is to easy to pass up. I also was skeptical about relying on a resource out of country for a larger turbo. I'm already getting much more out of the JSW TDI then I expected.Yep this thread is awesome!! I would not have had the balls to try a turbo swap on my car unless the details were ironed out. To me, spinning a wrench to physically do the swap is the easy part - the R&D in the swap is the hard part.
Besides using a spacer for the EGT sensor so it does not hit the other side of the manifold, it literally just bolts into a US CR-140 car.
Good to hear about the intercooler adding quicker spooling even after you had already done the stage 2 tune, makes the price tag easier to swallow.
Nice, so is the ECU still heading out for the tune?Just took my 2 micron pure flow off and took the car for a run, right to redline in 3rd perfect. No cel or limp mode.
If you're talking about the intercooler pipes, the benefit is the factory pipes leak at high boost. They possibly have better flow from having a larger, more consistent diameter. If you choose to keep the factory intercooler though you'll still have the clip connections.Ok, I have a dumb question... Any benefits by running the race pipes from dark side?
That is strange, perhaps the return line has restriction, causing higher than normal delta-rail pressure??Just took my 2 micron pure flow off and took the car for a run, right to redline in 3rd perfect. No cel or limp mode.
Long as I could get you a correct few logs without the car shutting down @ 3,500 - 3,800 RPM I'm happy. Hammered 2nd, 3rd & 4th to redline and did not limp the car. I will be in touch @ the end of the week so you can work your magic !That is strange, perhaps the return line has restriction, causing higher than normal delta-rail pressure??
Glad it solved it ;-))
Jeff
You have a PMI have new extra inlet pipe and elbow for this conversion. Please PM me if interested.
so is the car still not going into limp mode with the 2micron kit removed?
I think your set-up and approach when done will be just as good as it gets for a CR 140...Well that is good to hear.. wish my issue was that easy
I have sent a couple messages to 2micron to purchase the parts i need to install my CP4.2 but i think he may be busy.. because i have yet to hear back from him yet..
I'm not doubting you, just very curious. With a tune & full exhaust you only have 1 monitor not ready? Have you actually passed a MA inspection with the car plugged in, or just a visual. I know the Rawtek deletes the LP EGR, is your HP still functioning?I saw some posts earlier about all these mods failing New York Inspection. Mine did not.
Even with the EGR physically deleted, and not yet tuned to remove the "not ready" indicator, I still passed. (One not ready indicator is allowed.)
Someone's watching over you. I read the NYS inspection law several times and to my knowledge you're allowed 0 not ready lights. I know in MA your allowed one not ready light. The machine will give you an automatic failure and it's online with DMV. There must have been some glitch some where in your favor.I saw some posts earlier about all these mods failing New York Inspection. Mine did not.
Highly recommend these mods. Its super fun to drive my TDI up to a GTI and watch them grind their gears trying to catch me. I love the sound of my exhaust. It makes my GF soak her panties. Have not logged the 3's on a dyno yet, or even finished the stage 3 tune to the ecu, and I am grinning like an idiot ear to ear every time I hit the accelerator. Cannot get the stage 3 tune fast enough... next week.. I hope...
I cant say anything bad about parts and people I did not use, but I have the highest praises to sing about Mark Malone, and Nick up at Rawtek. These guys are awesome, their parts and their tunes are spot on, and you guys on this forum are great too, most especially JFettig, without whom I would never have thought to even attempt a CR170 swap. You Rock!
BTW, anyone in the new england area who wants to do this, my Mechanic, Mike, is an expert now, having suffered the learning curve on my build out with me. He is in Worcester, MA and happy to do it again.
