My O1M is sitting on a table in my driveway right now. I had to get it pulled to replace the torque converter oil seal which malfunctioned and let all the juice out. (About 100,000 miles on it.) While the trans is out I want to replace the filter and jack up the little clicker a few clicks. And I planned to replace the final drive fluid also.
So tomorrow I'll try to unscrew the speedo drive and take a look. Meanwhile, I cannot find a drain for the final drive. So do I pull the cover off the end (don't want to and don't have a gasket on hand) or suck out with a suction tool (trans is cold, and I really want the settled out gook that may be on the bottom), or turn unit over and pour out the speedo sender hole (again, cold trans and gook will have to run over all the gears and bearings), or just top it off? Perhaps a flashlight and a sampling will help decide.
Depending on my mood after this operation, I will try to report my findings.
