Has anyone removed the right engine mount bracket that bolts to the engine? If so how do you get it out? Getting it loose is no problem but out I'm not so sure about.
I was able to get mine out through the bottom. You have to raise & lower the engine while you do this for clearance. You also have to remove the lower IC piping from the turbo.
