oilcan_boyd
I recently acquired a 2005 Wrangler Unlimited. I plan to swap the ALH from my golf into it within the next few weeks. I have found quite a bit of info on here.
I have one question so far...
Will I be able to use the VW A/C compressor? I know it is a variable displacement type. Is it controlled like most others with a simple on/off switch or is the electrical signal more complex than that?
There is a company nearby that can manufacture hoses for it.
I will try to keep a detailed record of the process.
https://youtu.be/nDR7QtRpqlY
