gvf
I have a 1997 Passat TDI. The engine was recently rebuilt and one day the bottom radiator hose popped off, . Now it has a knock. Pulled the pan off, and #1 cylinder appears to have some scoring. What would you do?
I guess it depends on what rebuild meant.I have a 1997 Passat TDI. The engine was recently rebuilt and one day the bottom radiator hose popped off, . Now it has a knock. Pulled the pan off, and #1 cylinder appears to have some scoring. What would you do?
I would imagine OP meant that it overheated after the hose came loose.I guess it depends on what rebuild meant.
Did the engine overheat? Where are the details post hose falling off. In of itself, it's unrelated unless this was a chain of events.
