Since the wheel bearing races are inserted into the new rotor, and the bearings are matched to the races (when used), it makes sense to just go with new bearings. They aren't that expensive.
I have not known anyone to remove the race and install it in another rotor, but you can if you want. Just use a soft metal drift to knock the race out and install it in the other rotor, otherwise you can damage the surface.
