Mk5 golf brakes
Vale
Tamworth
Mk5 2.0 got tdi
I have had to chang a right rear calliper on my mk5 golf 2.0 gt tdi 2004 whilst doing this I needed to change the flexi hose and the solid pipe that runs along the rear axel now I can’t get any fluid to bleed through
When I release the nipple no fluid and the pedal stays hard
jmodge
Greenville, MI
2001 alh Jetta, RC2 w/.205's 5speed daily summer commuter and 2000 alh Jetta 5spd swap, 2" lift, hitch, stage 3 TDtuning w/.216's winter cruiser, 1996 Tacoma ALh
have you hooked up VCDS and cycled the abs valve?
pdtdiarl
EU
golf4
Does it happen you unscrew the flexi hose from the rear calliper?
Is the hand brake released?
