UhOh
No, oil was not (wasn't specified it was done) added FOR the compression test. The were concerns that residual oil might have altered the compression numbers, but it seems like any such oil is likely no longer there.My luck the used motor would be available now but when the motor takes a dump I won't be able to find a used one.
Must have missed where oil was added for the compression test.
Even if a ring broke the head would have to come off and the same height check.
If no one knew otherwise and was given these compression numbers no one would be offering up the possibility of a bent rod.
I see the following as possible ways to go forward with this:
1) Drive it and monitor (if other signs of problems then look to get ready for a big job), perhaps run another couple of compression tests after a little bit;
2) Pull the head and check piston-to-deck height- and if you find what you're likely going to find then you're pretty much then committed to correcting it (even though it may not be all that significant, as the recent compression numbers seem to show).
One could pick up another engine and rebuild it and have it available as insurance. I've got a complete car just for this reason! (zero down-time)
