Cribb
Hi,
I'm from sweden but I want to see if anyone over there have any good ideas to help me find out what's wrong with my TDI.
It's a 2003 VW Caddy 1.9 TDI with the ALH engine.
Bought it recently to replace same model that's a rust bucket so I have parts to swap. The problem was present at purchase but I thought I could fix it since I've had similar problems with my old car but no luck so far...
It's runns fine on idle and no smoke or something else wrong with it except it lacks power like I have no turbo.
First and second gear feels ok but third and up it feels weak. I can get it up to 130kph but it takes time and upphill it does about 80kph.
It never goes in limp and I'm not getting any fault codes.
I have ordered that vcds cable but it haven't arrived yet.
So I've tried to figgure out what the problem is for a couple of weeks now but I'm not making much progress
Here's what I have done so far:
I replaced the MAF
I installed a new air filter and cleaned the intake manifold/EGR
Cleaned the air intake
The VNT vanes are moving freely
I replaced all the vacuum hoses
I replaced the Boost pressure valve N75
I replaced the fuel filter
Checked the fuel flow from the tank and it runns freely
(no pump in the tank on this one)
Turbo sound ok
Cam belt looks fine
And as i said no fault codes...
Any ideas much apriciated!
I replaced the MAF
Turbo sound ok
Cam belt looks fine
