josh8loop
- Joined
- Sep 15, 2009
- Location
- Vero Beach, Fl.
- TDI
- 2002 VW Jetta TDI Manual(performed 01M to 5-speed swap) - 183,000 miles and climbing!
Fellas,
I have had a nagging coolant leak for some time now. I found a small crack on the expansion tank that I fixed, and one other small coolant leak from one of my other coolant hoses which is now fixed. Unfortunately those two leaks were very small and my issue appears to be elsewhere. It's to the point now that I am adding 1/3 gallon for every 57 miles I drive.
This past weekend I lifted the car up and found evidence of coolant leaking from the lower passengers side of the engine directly under the crank seal. Obviously it's from some component above the crank shaft like a water pump or something else. There are no other coolant leaks on the vehicle. I have checked all other possible locations(for instance the hard coolant pipe O ring) and found no other leaks. I did a full TB job 60K miles ago using very high quality parts from our trusted online vendors here so I'm having a hard time believing it's a bad water pump seal. I went ahead and ordered a new water pump(HEPU brand made in Germany w/ metal impeller) that should be here the end of this week. Only question I have now is if there are any freeze plugs on the TB side of the engine that have been known to leak? Any other areas I should be checking for leaks?
