oliveone
- Joined
- May 8, 2003
- Location
- Hudson Valley
- TDI
- 1999.5 Jetta GL, 2002 Jetta, 2005 Passat, 2009 Jetta 6 speed M new baby :-) 2013 Passat 6 speed M Silver
Back ground 1999.5 Jetta with 241,000 mile runs great. I have owned the car since 37,000 miles. The AC system is having an issue that I cannot seem to figure out. When the heater/AC blower fan is on one the AC works ( The compressor is engaging and the system gets cold). I have checked the A/C high and low sides and both are good. The radiator fan starts as soon as the AC button is pushed and when blower fan is on one. Note on heater/AC blower fan setting one the fan motor that is used to push the cold air is not working. The AC is getting cold but no fan to push around the car. When I turn the fan speed to 2-4 the fan blows as normal but the AC turns off ( light turns off for AC, fan under hood turns off and compressor turns off). Every now and then the AC will work in 2-4 on blower speed. When it was 79 last week and the AC would not work for the 3 hour drive it was on was a PITA. I have taken the dash apart to check the back of the HVAC head unit and did not find anything loose. Any help would be great.
Jason
Jason
