bustNfuel
I finally had the time to install my Kenwood TM-D710.
After looking for a relatively easy way to run the power cables from the battery, through the firewall, under the dash, down the side of the door sills/carpet back to the trunk, I decided to use the trunk mounted 12V
power supply. The current draw of the Kenwood at high power is half of the rated capacity of the 12V outlet, and I don't plan on running full power, so this arrangement is much simpler. I mounted the main RF unit in the trunk, up underneath, opposite the Sirrius unit.
For the antenna, I used a trunk-lip mount, of which there are several manufacturers that will work. I don't want to drill the trunk or the roof, due to potential leaks and future resale value hit. The antenna I am using is a Comet SBB-5, which has great asthetics and performance.
From the trunk I ran the control head cable and microphone cable under the back seat, up over the carpet to the center console area to the radio control head. For now I have the control head mounted up in the cubby hole forward of the shifter. I tried using Velcro with sticky backing to mount it between the shifter and the cupholders but the Velcro did not adhere to the plastic center console more than a few minutes. There is a hamfest in April that always has an assortment of mounting hardware. I'll probably use a pedestal mount of some type, but preferrably not one that takes up a cupholder or requires me to drill holes that are visible after the radio is removed at a later date.
Here are a few images of my install, which I have yet to tidy up with wire loom.
