I was thinking of doing the topside oil change at first. The part that worries me is not changing the filter. I've been getting the Hengst filters from ID parts and they seem like a good brand. I never thought about the oil analysis though. I'll do that the next oil change and see how it comes out.I think you'd be better off sucking out the oil topside and changing the filter every other change. Also, maybe do a UOA or two and extend the interval a bit if the results are positive (they should be).
Thanks for that. I knew about the system just hadn't heard that term.
It's not really a relocation kit, it keeps the original filter and adds a ultra fine filter. My understanding about the bypass is that it will extend the original filter life by removing soot. Of course these are the claims, I've no experience with it yet. But if I do install it I'll monitor it with oil analysis. I'm going to do one at my next oil change to give me a baseline. The car has 38,000 on it know so it's probably a good time to see what it's doing.start sending oil changes to blackstone oil lab for analysis. word is that you can milk the oil changes out to 13K to 15K oil filter has NOTHING to do with oil change as good filters can go for 20K. better off paying up for a better filter
IMO if you DID go with a relocation kit, i would cram in there a 10 micron cat filter with a wix heavy duty adapter. filters are $20 a pop, the adapter relocator is $30, some 3/8 fuel line, some fittings, proper hose clamps, and an adapter to stand off from the original location for another $100. call it a good $200 to do the job and what did you save? the filters are not going to last any longer! so whats the point? making the oil last as long? its not just about contaminates. Oil has viscosity and that changes as heat breaks it down. nots not about the dirt, its the heat. Your not going to be able to push the oil to 20K unless you stray from the oil spec you need for the car. That 20K oil is actually just that but your not going to get the oil you need.
i would just send your oil out for analysis and see if you can push it further. and save your $
The OP has an entirely different engine than you do.I commute 700 miles a week with my 2014 Passat now at 202k miles, changing the oil and filters at 10k intervals topside. With a Pela extractor I can change both in ~ 30-45 minutes, including clean-up. Get the ten pack of filters from ID Parts. Good luck, John
