WMO 50/50 mix
I did it... works fine. sometimes you need to over look all the I'm a chemist BS, stop being nervous and see whats being done... I have a centrifuge I built with some washer machine motors to get the big gunk out of the WMO (waste motor oil)... then I run my cleaner WMO through a pressure filter rated for 5 microns... pour it in a 55 gallon drum. the drum has 2 wal-mart heating pads duct taped to the lower half. once the the now much cleaner WMO is in the drum and about half full, I fill the rest up with Diesel fuel or home heating fuel... "same-ish thing". Next, I blend using a 5gal 3 foot long paint mixer attached to a drill... mix until I'm happy which some days is pretty quick, maybe 5 mins... Last I put it in my tank and go to work... I drive an hour to and from work every day... I get a little smoke then the car warms up and normal as it can be.
here is a side note on Doing what you told
My wife bakes bread... she started out following the directions to the "T" and the the bread was always the same... one day I said what happens if you add more yeast... or honey? She in so many words said "uhuhuh" or in English "I'M NOT SURE" ... I said lets try .... you know what we got ... fluffier and sweeter bread.
TDI's are tuff ... if its your daily and your hesitant about experimenting, don't untill you can... otherwise add some more honey.
