prometheum
The car has 194k miles on it currently. I'm planning on the following:
Timing belt replacement
Camshaft inspection and replacement if required (is there a recommended aftermarket camshaft that's not as prone to premature wear that's recommended?)
Fluids and filters changed (transmission, brake fluid, oil, fuel filter, both air filters)
