touaregv10tdi
- Joined
- Jan 29, 2006
- Location
- Fort Lauderdale - Florida
- TDI
- 2013 Beetle TDi,2000 Beetle TDi, 2016 BMW X5 Diesel, 2004 Touareg V10 TDi,2015 Beetle TDi, 2005 Jetta TDi
Alh injection time VCDS - VIDEO
Many of you already seen this, since it might get lost on older threads, I decided to post once again.
Today I set the injection time on my beetle tdi. You need a VCDS software to perform this configuration.
Make sure your engine is at normal operating temperature.
Remove the intake hose so you will have access to the injection pump sprocket. (Make sure your engine is NOT running when working on those bolts at the injection pump)
Before you remove the hose, hook up your VCDS to see where your timing is.
Turn off your engine, remove the intake hose, lose but not remove the three bolts from the injection pump sprocket. To retard the timing, use a 22 mm open end wrench move the big nut from the injection accordingly.
To advance the time, move it towards the radiator. When I say move it , it is just a hair. Tie up the three bolts, put the intake hose back on, start the engine, check the time again. Repeat the procedure until desired time is achieved. I like mine just a little advanced. Video below shows where I set mine.
https://www.youtube.com/watch?v=EG8QrMLs5iI
Once you have the correct time, torque the bolts for the injection pump sprocket to 15 lbs plus a 1/4 turn. Pop you hose back on.
Done.
- Start VCDS
- Click [Select]
- Click [01-Engine]
- Click [Meas. Blocks - 08]
- Go to group 000
- Click on do it
- Click [Switch to Basic Settings]
- Click [TDI Timing]
- Select your engine code from the drop-down menu
Done.
