81golfcaddy
I posted this in the tdi 101 but got no chimes on it. this is a 91 corrado that has a 98 jetta tdi full swap. engine is running great getting 44 to 45 mpg. plenty of power also. I had the timing checked on the vag and it is good. no engine codes. at light throttle at 1500 to 1800 the car will buck pretty bad. you have to either let off the throttle or give it more then it will go away. could it be the throttle position at the gas pedal going out? if so should it throw a code. soon as I get this issue resolved it will go up for sale. it is my daily and that is the only issue
