Update: used VCDS during cranking and am seeing RPM 2-400 RPM and the following codes. Note that I cleared these and they came right back, not sure why they're so persistant
Also am seeing the following under engine group 13 during cranking. Does this mean the ecu isn't commanding any fuel?
Address 01: Engine Labels:
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55AF4D51AC427BE2DE-FFFE
8 Faults Found:
16627 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 000 - Malfunction
Freeze Frame:
RPM: 0 /min
Torque: 166.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00001000
Absolute Pres.: 183.6 mbar
Absolute Pres.: 2182.8 mbar
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 166.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00001000
Torque: 56.0 Nm
Torque: 108.0 Nm
16567 - Fuel Temp. Sensor A (G81)
P0183 - 000 - Open or Short to Plus
Freeze Frame:
RPM: 0 /min
Torque: 166.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Temperature: 133.2°C
Temperature: 30.6°C
Temperature: 38.7°C
16497 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 166.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Temperature: 30.6°C
Temperature: 38.7°C
16622 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 166.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00001000
18074 - PD Unit Injector; Cylinder 1 (N240)
P1666 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 504 /min
Torque: 196.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Inj. Quantity: 0.00 mg/str
Temperature: 38.7°C
(no units): 128.0
18077 - PD Unit Injector; Cylinder 4 (N243)
P1669 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 273 /min
Torque: 202.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.49 V
Temperature: 38.7°C
(no units): 128.0
18076 - PD Unit Injector; Cylinder 3 (N242)
P1668 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 378 /min
Torque: 196.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.49 V
Temperature: 38.7°C
(no units): 128.0
