scrambld
- Joined
- Jun 26, 2004
- Location
- Belchertown, MA
- TDI
- '06 Jetta...TDI/5spd :) >>>now a '15 Passat TDI/DSG
Ok....so a little history. I have an '06 Jetta TDI (O'course...). Replaced a failing DMF w/SMF Vr6 clutch. Soon after I had a Stg2 downloaded by my local TDI mastermind (very happy he is local). I was very pleased with the Stg2...very pleased. Did I say very pleased? This is how it should be....the roll on in any gear was just fantastic. It'll pull from as low as 1400-1500rpm's....and I mean pull with no lag what so ever! Down shifting was actually no longer needed.
Now, fast forward. Failing BRM turbo actuator...symptoms: very lazy from anything less than 22-2300rpm's after that it would crank as it always did. Really lacked power unless rpm's were up, down shifting now required all the time for hills/passing. Decided on an "upgrade" PD140 turbo/3 bar MAP sensor and have TDI installer contact Malone for upgrade tune to Stg4 w/3 bar MAP and allow more boost into the equation.
Well, got the car back with the upgraded turbo/tune and it turns out to be more of a down grade....actually back to the failing BRM actuator rod issues all over again....very lazy until about 2000-2200rpm's then it'll pull. It really lags under that window where before it would pull like mad!
Now, that lag is one thing. But, my Malone installer/contact tried to email Malone about 2 months ago with no response (I was told he was on vaca until the end of July...Ok...it's mid August now). I emailed Malone about 3 weeks ago....and still nothing. I asked Malone if he could review the numbers and see where the problem might be?
I do realize that Malone is tough to get a hold of but I don't know about the rest of you guys....but when you pay xx for a service and then pay xxx for an upgrde to that service I think you'd like results. And, if you don't the get the service or results you had planned on you'd be asking questions.
So, can any one give me a heads up on how long you had to wait to hear from Malone on past inquires?...Even just an estimate of time? Am I in the ball park of 2 months? Or has it been longer? Waiting patiently.....but it's getting old now!
PS...I have posted on here about the possibility of adjusting the actuator rod.....it may be needed/or it should be pretty spot on is what I am hearing. So, I was awaiting Malone's response before I touch anything......
