I suck at charts, and don't know how to superimpose or to change axis info
http://i72.photobucket.com/albums/i189/H2O2H/Data%20Logs/RPM.jpg
PM me your emailBob_Fout said:We need to both requested and actual, along with RPMs.
You can e-mail the CSV file to me if you'd like.
Those are mostly at 2nd and 3rd gear runs, no 4th gear runs were done.Bob_Fout said:Is there a part of this log that's a 3rd or 4th gear pull that's WOT from 1800 to 4000 RPM?
OK, can we get just a 3rd gear run, start rolling onto the go-pedal at 1400 or 1500 RPM, WOT by 1800 or 2000, until 4,000 or 4500?H2O2H said:Those are mostly at 2nd and 3rd gear runs, no 4th gear runs were done.
OK, I will try and do that now, and will get it to you asap.Bob_Fout said:OK, can we get just a 3rd gear run, start rolling onto the go-pedal at 1400 or 1500 RPM, WOT by 1800 or 2000, until 4,000 or 4500?
The shop that did the install sourced it directly from SBC, but I would recommend buying an SBC or DC clutch from one of the several TDI Club vendors.H2O2H said:Where did you pick up your stage 3 hybrid clutch?
I need to order a SB stage 3 with 22lb smfw.
Got a governer-ish thing kick in at 4400 rpm. Wth is that???Bob_Fout said:The shop that did the install sourced it directly from SBC, but I would recommend buying an SBC or DC clutch from one of the several TDI Club vendors.
I don't have a VAG-COM, just a VAD. So, it's only the two MAP's, RPM and Time on one log.Curious Chris said:Ah yes the best diagnostic which I credit to Drivbiwire: warm engine, logging Specified MAF, Actual MAF, Specified MAP, Actual MAP, and throttle position, 3rd gear stock, 4th gear modified, 100% throttle from 2000-5000 rpm, repeat 3-5 times.
The longer you can keep it at 100% throttle, the better the data will be. I know in my car I do not get full boost in 3rd gear, only 4th and 5th.
Hm, 3rd gear with RC3 should pull right to the limiter of 5100 RPM.H2O2H said:Got a governer-ish thing kick in at 4400 rpm. Wth is that???
Then threw a code.
DTCs: 4/4/10 10:07 pm - 1 Faults:
G120SG 2839
P/N: 038 906 012 CP
Coding: 00002, WSC: 00001
17969 P1561 163
Quantity adjuster -N146: Control difference [sporadic]
To me, the car does not feel like it used too.Bob_Fout said:Hm, 3rd gear with RC3 should pull right to the limiter of 5100 RPM.
Your CEL could indicate some oddness with the IP.
You're welcome.H2O2H said:To me, the car does not feel like it used too.
Kind of a held back feeling.
Wonderful
Oh, thanks bob for making those graphs, I really appreciate it!!!
Give KROUT a jingle.H2O2H said:Jacksonville, FL
And I just ordered nozzles, ughhh.
You think VAG-Com IQ adaptations may be responsible for that?
Who said that?H2O2H said:My VW mechanic says that "It's a difference in fuel consumption in between cylinders" and need to do a compression test on them first.
Oh that does not sound good!
Bob_Fout said:Who said that?
Does your car smoke at idle or smoke under low load?
Check out your idle balance, group 13. Fully warm engine, all accessories off.H2O2H said:Didn't notice any smoke today, only the slight haze on WOT.
It's not the pump, that gut feeling is usually right. Don't know why my mechanic wants to do a compression test on each cylinder, and also said that, that code can come from a sig injection variation btwn each injectors.
So, I have some ideas...
Can the dealer reflash my ECU to stock? Like to get rid of the aftermarket tune? Or, should I try and find another ECU somewhere cheap, have them mate it to my car, and run that for a while? Maybe after a break, I will get the mod bug again. But, I think I am about done!
I think you have a log of that?Bob_Fout said:Check out your idle balance, group 13. Fully warm engine, all accessories off.
