Dopie
after a friend of my got me got infected with the virus TDI i decided to build one myself.
(im from the Netherlands so don't me a grammer hater)
bought a mk2 from a Mc Gyver. Now I know I should never do it but if you learn from your mistakes
day 1
i replaced almost everything on the car like:
turbo
2cilinderheads
CYP gearbox(diff exploded) to ASD gearbox(1z longer 5th)
padelbox for a stock mk2 converted elec. gas to cable clutch to cable
stronger clutch with machined/spun g60 flywheel.
MB IC
other radiateur with spalfan
new ic tubing
bigger 11mm pump
mk3 subframe vr6 suspension
corrado vr6 front motormount beam
trow away the small 256mm stock brakes replaced with ebc 280mm vr discs audi S2 calipers with ebc Yellowstuff
mk2/3 disc brakes at the back
bigger 25,4mm non-abs brakecilinder
uniball whisbones
2.5" straight exhaust
coilovers
powerflex blackserie rubbers
battery in the back
mk2 GTD tacho
replaced engine after hydro lock
for full dutch topic see
http://www.vwforum.nl/even-voorstellen-f6/dopie-s-golf-mk2-tdi-t174917.html
the car how it is now.
the car is almost done. i only need to replace the brake hoses at the back and aligning the car so it can go to the annual inspection. after that I gonna replace the afn turbo for a gt1749VA and 0.250 injectors also got a chipped ecu for around 160pk. after that I gonna drive the car allot and gonna complete my other builds mk1 cabby 20vt(AYP) and mk2 2.9(ABV) VR6. iv I finished that cars I gonna build another mk2 TDI but on a higher level
day 1
turbo
2cilinderheads
MB IC
new ic tubing
bigger 11mm pump
uniball whisbones
coilovers
battery in the back
mk2 GTD tacho
