hey guys
I have a 06 TDI Golf and i recently changed the air filter to a K&N reusable. Some people warned me about this and the problems i might have with the Air Flow Sensor in time ... and that it would be damaged by the fine droplets of oil off the filter.
This was a brand new filter and i installed it ... oh maybe a month back.
Since then i've gotten the error code on my dash twice.
The first time around i thought it was because i had unplugged the air flow connector while the keys were in the ignition. I wasn't sure if that was the case or not. So i reset the codes. This was last week on Wednesday. Yesterday i just got this error code again - P0101 - MAF or VAF CKT Range/Perf?
Some say that it could be the EGR valve and that i should simply block it and reprogram the ECU to not even use it. Not only will this eliminate the error codes from coming up, but it'll actually give me better performance from the engine.
I need some ideas as to what this could be. Should i check the EGR? Seems pretty coincidental that it started failing right after i changed the air filter.
Also if it is indeed the air filter, would the sensor return to normal if i were to go back to paper air filters?
Thanks much for your input.
